Na deze foutcode de luchtmassameter vervangen, maar na de foutcode's verwijderd te hebben, komt de melding weer terug.
Wat kan het probleem zijn?
1 Fault Found:
7330 - Mass Air Flow Sensor (G70)
P0101 00 [101] - Implausible Signal
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 203665 km
Date: 2019.08.26
Time: 17:26:10
Engine speed: 1230.00 /min
Normed load value: 0.0 %
Vehicle speed: 65 km/h
Coolant temperature: 87 °C
Intake air temperature: 38 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 13.779 V
Unlearning counter according OBD: 40
Sensor for temp after charge air cooler: raw value-TBA_MES: 38 °C
Charge air pressure: actual value-MAP_MMV: 1119.22 hPa
Air mass: actual value (mg/stroke)-MAF_MES: 515.733 mg/stroke
Air mass: specified value-MAF_SP_MMV: 516.90 mg/stroke
EGR Vacuum Regulator Solen.val.: activation-ANG_SP_EGRV[0]: 0.000 %
Throttle_actuator_commanded_value-ANG_SP_THR[0]: 96.001 %
Charge Pressure Actuator: activation-ANG_SP_BPA[0]: 84.369 %
Readiness: 0000 0000
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 203665 km
Date: 2019.08.26
Time: 17:26:10
Polo 6R
1.6 TDI 140pk (by VAGTECHNIEK)
