Zekering overzicht polo 9n
Voormalig teamlid
4,533
1,201
208
Bron: Internet.
MyPolo is niet aansprakelijk als dit overzicht niet klopt!!!
Controleer dus wat je doet.
Fuse box in passenger compartment Volkswagen Polo 9N.
The fuse holder is located behind the cover in the left side of the dash panel.
fuse box diagram.
legend
F1
(10A) Rear screen wash/wipe system
F2
(5A) instrument illumination rheostat, licence plate lamps
F3
(5A) Rear fog lamps
F4
(5A) Brake pedal position (BPP) switch, cruise control, engine management
F5
(5A) Engine management
F6
(5A) Head lamp adjustment
F7
(5A) Engine management, power steering
F8
(5A) Heated door mirrors
F9
(10A) Engine management
F10
(5A)S-contact
F11
(5A) Electric/heated door mirrors
F12
(5A) RH side/tail lamps
F13
(5A) LH side/tail lamps
F14
(10A) Engine management, intake manifold heater
F15
(10A) Automatic transmission (AT)
F16
(10A) Wind screen wash/wipe system
F17
F18
(5A) Air conditioning (AC), AC/heater recirculation, alarm system, anti-dazzle interior mirror, engine coolant blower motor control module, instrument panel, navigation system
F19
(10A) Heated wind screen waterjets, reversing lamps
F20
(5A) instrument panel
F21
(10A) RH headlamp- high beam
F22
(10A) LH headlamp-high beam
F23
(10A) Anti-lock brake system (ABS), electronic stability programme (ESP)
F24
(10A) Multifunction control modulel
F25
F26
(10A) Stop lamps
F27
(5A) Anti-lock brake system (ABS)(with ESP), instrument panel
F28
(10A) Interior lamps
F29
(5A) Air conditioning (AC),data link connector(DLC), telephone
F30
(5A) Multifunction control modulel, AT selector lever lock, wind screen wiper rain sensor
F31
(25A) Electric window motor, front left
F32
(15A) Heated seats
F33
(15A) Alarm system horn
F34
(15A) Auxiliary power socket
F35
(20A)Sunroof
F36
(25A) AC/heater blower motor
F37
(15A/20A) ignition coil(s)/ignition amplifier(s)
F38
(25A) Electric window motor, rear left
F39
(25A) Electric window motor, front right
F40
(10A/30A) Engine management
F41
(15A) Fuel pump/fuel lift pump – petrol/TDI
F42
(20A) Engine management-AXU
F43
(15A) RH headlamp- low beam, head lamp adjustment
F44
(15A) Front fog lamps
F45
(15A) Engine management-AUB
F46
(20A) Wind screen wash/wipe system
F47
(20A) Heated rear window(^02/04)
F48
(15A) indicators/hazard warning amps
F49
(15A) Cigarette lighter
F50
(15A) Multifunction control module2, alarm system, central locking
F51
(15A) Audio system, navigation system
F52
(20A) Horn, windscreen wash/wipe system
F53
(25A) Electric window motor, rear right
F54
(15A) LH headlamp- low beam, head lamp adjustment
Ik ben met dit overzicht aan de gang gegaan nadat ik het had gevonden en het klopt wel voor zover ik zekeringen heb gecontroleerd. Toen ik de zekering voor benzine er uit trok ivm vervangen brandstoffilter stopte de motor ook gelijk na starten... dus ben wel erg blij met dit overzicht. Hopelijk hebben anderen er ook wat aan.
Waarderingen: DeeOow
Beste lezers,
Beginnersvraag:
Bij mijn polo 9N 1.4 werkt de sigaretten aansteker niet meer. Die heb ik gebruikt om mijn telefoon op te laden tijdens het rijden, voor navigatie.
Nu wil ik de volgende zekering vervangen:
F49 (15A) Cigarette lighter
Is het een kwestie van zekeringen bestellen en dan bij de passagiers kant de zekeringskast openen en dan de betreffende zekering eruit trekken en de nieuwe erin drukken? Welke zekeringen bestel je hiervoor?
Mis ik dan nog iets?
Daarnaast: heeft iemand ook ervaring met de sigaretten aansteker die het niet meer doet? Je telefoon daarmee opladen moet toch wel kunnen, right?
Hartelijk dank,
Felix
Volkswagen  9N  1.4 16v
@Felixvdb Welkom op het forum, een voorstel topic met meer informatie over je Polo wordt zeer op prijs gesteld, en als je er ook nog foto's bijplaatst dan gaat iedereen los hier. ;)
Ik zou even alle zekeringen nakijken, die kan je één voor één er uithalen, kijk je of er in het midden een breuk zit (door gesmolten), en die plaatst je weer terug. Heb je een doorgebrande zekering dan koop je er één met dezelfde kleur/waarde en die plaats je terug. Bij een Praxis, Gamma, benzinepomp, automaterialen zaak, kan je die kopen. Je telefoon opladen met de "sigaretten aansteker" moet normaliter wel kunnen.
Ik zie dat het foutief staat boven.
De zekeringen zitten bij een Nederlandse auto aan stuurkant.
Waarderingen: Felixvdb
